QT GUI Help
Solved by ExidCuter,
2 hours ago, boxama said:You could try and use HTML markup (setHTML) instead of simply raw text and a stylesheet.
You'd have to search the text and replace it, eg:
string.replace( 'myword', '<font color="#FBFBFB">myword</font>' )
Thanks, but I have solved it.
The solution:
QString searchString = ui_lineEdit->text(); QTextDocument *document = ui_textEdit->document(); bool found = false; if (isFirstTime == false) document->undo(); if (searchString.isEmpty()) { QMessageBox::information(this, tr("Empty Search Field"), "The search field is empty. Please enter a word and click Find."); } else { QTextCursor highlightCursor(document); QTextCursor cursor(document); cursor.beginEditBlock(); QTextCharFormat plainFormat(highlightCursor.charFormat()); QTextCharFormat colorFormat = plainFormat; colorFormat.setForeground(Qt::red); while (!highlightCursor.isNull() && !highlightCursor.atEnd()) { highlightCursor = document->find(searchString, highlightCursor, QTextDocument::FindWholeWords); if (!highlightCursor.isNull()) { found = true; highlightCursor.movePosition(QTextCursor::WordRight, QTextCursor::KeepAnchor); highlightCursor.mergeCharFormat(colorFormat); } } cursor.endEditBlock(); isFirstTime = false; if (found == false) { QMessageBox::information(this, tr("Word Not Found"), "Sorry, the word cannot be found."); } }
