Idle temps seem good. The max temp is getting a bit close to 90 degrees but honestly you'll be absolutely fine. As long as you arent running some stress test 24/7, you'll be fine. If you're worried about the temps, try adding another fan to the cooler if you can, buying a better fan for the cooler or ensuring that you have adequate air flow from case fans. But yeah, as Nacho said above, you can push it further.
https://linustechtips.com/topic/552138-i5-4690k-safe-temps/#findComment-7283897
That's a good chip you got there mate, you can push it to 4.8 and maybe even 4.9 with a good cooler and at a higher voltage.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/552138-i5-4690k-safe-temps/#findComment-7283909
Anything below 90c, but try not to reach 80c and above.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
https://linustechtips.com/topic/552138-i5-4690k-safe-temps/#findComment-7283929
pretty good, i would say its OK up to 85-90C, 55C when gaming is really good tho :)
Builds:
https://linustechtips.com/topic/552138-i5-4690k-safe-temps/#findComment-7283980
