The headset has really short cables. If i would use an extension cable, would if affect the quality? Its very important for me (the quality). Its 3,5mm jack.
+ Could you recommend good extension cables?
Asus Z170-A | Intel Core i7-6700K@4.6Ghz | Cooler Master 612s | ZOTAC GTX 980 AMP! Extreme 4GB | Kingston HyperX Savage 1x8Gb 3000MHz CL15 | Aerocool Mechatron White Edition (Steel Edition) | Corsair CX650M | Fostex HP-A3 | Windows 10 Professional 64Bit | Superlux E205U | Samsung 840 Pro 256Gb | Seagate Barracuda 500GB 7200Rpm | BENQ XL2411Z (1ms, 144hz, 24'', 3D) | HiFiMAN HE-400i | Logitech G910 Orion Spectrum | Logitech G703 Wireless | Razer Goliathus Control Large | T-Moblie 120/10 Mb/s | Steam profile
https://linustechtips.com/topic/552123-denon-ah-d400-cable/
Unless you plan on running a very long extension cable, then it will be just fine.
Just buy an extension cable in a price range that fit you.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/552123-denon-ah-d400-cable/#findComment-7283795
