No picture but would be glad to help :)
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
I've been googling for a bit and it seems to be from MSI but I can't get the exact model. Can you plug it into your computer and start up GPUZ and it'll identify it for you.
I know you said you didn't want to but it's so much easier. You probably wont even need to install drivers.
Novus Anima
Laptops
Surface Pro 3
You could take off the heatsink and see if the card name is printed on the GPU itself
EDIT: Just make sure you re-apply thermal paste after you're done
A Guide For Getting Started With Linux
My first rig:   CPU: AMD Athlon X4 860k Cooler: Cooler Master Hyper T4 MoBo: Gigabyte GA-F2A88XM-DH3 Video Card: EVGA GTX 750 Ti Superclocked RAM: 8GB Kingston HyperX Fury White 1866MHz Storage: WD Blue 1TB PSU: EVGA 100-W1-0500-KR Case: Rosewill SRM-01
Do I have to remove my current GPU and unistall the drivers?
Not necessarily. If  you have a second pci express slot, you should be able to drop it in no problem. You could then use device manager to look at it, or GPUz or something to see its name.
