Hi everyone,
this is my first time here and I want to show you my latest project. Here I present to all of you Project Nightdiver!
I've started creating the skeleton of the case, using a premade motherboard base and a PCI bracket.
12540634_949553141747102_518336907546679
From a sheet af aluminum I've made the other panel and the support for the PSU.
12510328_949553135080436_201721558381299
12507523_949553105080439_606034596447634
12548978_949553271747089_268660280624863
Then, I used some iron to create the support fot the two panels.
944065_949553198413763_58424595347035189
1934856_949553248413758_7771442888946385
After that, made all the necessary holes and sanded for painting.
12548953_949553295080420_936224700654708
For the painting, I decided to use a simple black/blue code, in order to follow the colors of the components.
12508865_951942348174848_168282625385689
12540578_951942448174838_323756682720067
1929905_951942468174836_3539178559580431
12417636_951942488174834_410788919006250
12552627_951942571508159_537814211237989
12540717_951942991508117_691269596576389
12509023_951942291508187_569142130111274
12552566_951942948174788_644212940735070
Used some plexiglass to make backplates for the GPUs and a front panel to protect the components.
12717563_963517363684013_825153754680448
Put on the mobo and all the other things.
12644683_954180211284395_528970955650342
Bended all the tubes...
12711231_963517713683978_577000185151404
11057485_963517760350640_777266242921979
... and gone through the necessary leak test.
12694994_963517780350638_267433581787031
12711067_963517793683970_803062157874138
And the final result!!!
12734227_963517350350681_599322257400236
12698612_963517470350669_784027983405566
12672031_963517563683993_362185838849578
12688172_963517607017322_552460311721931
12742661_963517623683987_137409237738828
12688159_963517643683985_271028298120931
12742642_963517733683976_466695650422576
Hope you like it as I enjoyed making it.
Have a good modding time you all!
See you soon!
https://linustechtips.com/topic/551683-scratchbuild-project-nightdiver/
