I have a new uninterruptible power supply that advertises 330W. Will this be enough for my PC to keep running for a couple minutes when the power goes out? Is it safe to plug other things in(draw more watts)?
Power supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16842101343&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-UPS+%28Back+Up+Power+Supply%29-_-N82E16842101343&gclid=Cj0KEQiAuqC2BRDVxMSnpa-mhZoBEiQAFta8wVNsWMS5br6QztQaQgfh9jygGzFSWB1kNwsURMdDFjcaAmja8P8HAQ
PC: http://pcpartpicker.com/p/mkc3hM
https://linustechtips.com/topic/551641-uninterruptible-power-supply/
if your PC is at idle it will be fine and last for a few minutes
under load the PSU will struggle to put out the 300W that your PC requires and might actually shut off completely if the power goes out
As long as you're on the ball it should give you enough time to shut down. Though since you said you already have it you could just give it a try.
"The of and to a in is I that it for you was with on as have but be they"
1 hour ago, Savir said:
If I try are there any risks?
well with batteries and electricity in general there's always the risk of fire and explosions, usually followed by screaming, sometimes some running and almost always some crying and explaining afterwards.
