I'm building a new pc and would like some help. I will use it for vr, gaming and software programming. I also want it to be silent. Your advice and opinion would be greatly appreciated. Here is the hardware I came up with until now:
Graphite Series 760T Full-Tower Windowed Case
asus maximus viii extreme/assembly
asus rog matrix gtx 980 ti
Dominator Platinum Series 64GB (4 x 16GB) DDR4 DRAM 3000MHz C15 Memory Kit
Intel Core i7-6700K
intel ssd 750 series 400gb
WD 2tb internal hard drive black
cooler master MasterAir Maker 8
Silent Pro M2 850W
Arctic Cooling MX-4 4g Thermal Compound
BitFenix Spectre PRO LED green
https://linustechtips.com/topic/551551-build-advice/
Intel Core i7-6700K
Silent Pro M2 850W
Nice build! Why that RAM? Nothing wrong with it just breaks the bank :P
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/551551-build-advice/#findComment-7277763
Get a case with sound dampening such as Fractel R5/S/H440/ and replacing that loud cooler for NH-D15 or Dark ROCK 3, i would get NH-D15 as it easier to install.
Magical Pineapples
https://linustechtips.com/topic/551551-build-advice/#findComment-7277769
Just now, mcraftax said:
Nothing is silent if it has moving parts.
Not completing true ....
Magical Pineapples
https://linustechtips.com/topic/551551-build-advice/#findComment-7277775
Intel Core i7-6700K
Silent Pro M2 850W
whats your budget??????????????????
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/551551-build-advice/#findComment-7277777
Just now, Sham_gabz said:
Thx :). It took me a lot of time to design this build.
64gb is overkill. not needed.
Old Rig
https://linustechtips.com/topic/551551-build-advice/#findComment-7277796
2 minutes ago, mcraftax said:
In what way?
I have moving parts in my system and at idle is not even noticeable ... i have all my fan running at it lowest and i can't hear a thing unless you try to hear the damn thing.
Magical Pineapples
https://linustechtips.com/topic/551551-build-advice/#findComment-7277800
You can just download more RAM ;)
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/551551-build-advice/#findComment-7277801
I know the ram is overkill but I am sick of my programs slowing down because I have too many things open at once. I have experienced 16GB nut that was just not enough. Overkill for the win ;)
https://linustechtips.com/topic/551551-build-advice/#findComment-7277802
still havent answered my question, whats your budget?
wtf do you do with 16gb filling up? my 8gb rarely fills up...
Old Rig
https://linustechtips.com/topic/551551-build-advice/#findComment-7277808
3 minutes ago, Sham_gabz said:
Around 3500$
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($129.99 @ B&H)
Motherboard: MSI X99A Raider ATX LGA2011-3 Motherboard  ($202.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (2 x 16GB) DDR4-2400 Memory  ($214.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($148.88 @ OutletPC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($119.88 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($639.99 @ Amazon)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($115.98 @ Newegg)
Total: $2037.67
Generated by PCPartPicker 2016-02-20 07:37 EST-0500
Old Rig
https://linustechtips.com/topic/551551-build-advice/#findComment-7277829
Total: $2037.67
Throw in another 980ti ;)
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/551551-build-advice/#findComment-7277832
Total: $2037.67
Thx ;)
https://linustechtips.com/topic/551551-build-advice/#findComment-7277837
depends what monitor he has/or getting.
Old Rig
https://linustechtips.com/topic/551551-build-advice/#findComment-7277838
