I have this build and I wanted to know if it's pretty solid. Anything I can do to make it cheaper without sacrificing power? I thought about using the MSI Z97 PC Mate rather than the Krait Edition board. Didn't see a lot of quality reviews on YouTube for the PC Mate. I'll probably keep the GPU because I get a copy of Hitman with it from Newegg.
Thanks!
(I made that third topic anyway didn't I.)
https://linustechtips.com/topic/551449-build-advice/
No SSD on a build of that price? Ouch.
Also, that wifi dongle likely won't be that great unless you're in the same room as the router.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/551449-build-advice/#findComment-7276838
@Xaptik
PCPartPicker part list: http://pcpartpicker.com/p/Rqs3qs
Price breakdown by merchant: http://pcpartpicker.com/p/Rqs3qs/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($104.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($68.49 @ Amazon)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Other: h220x ($139.95)
Total: $1283.15
Generated by PCPartPicker 2016-02-20 02:53 EST-0500
Added an SSD, 16gb of RAM, different case, and better WIFI dongle
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/551449-build-advice/#findComment-7276847
1 minute ago, Xaptik said:
I just don't think I need an SDD honestly.
You won't think you need one until you realize the collective life's worth of time you're wasting by waiting for your HDD to load shit up.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/551449-build-advice/#findComment-7276857
3 minutes ago, shadowbyte said:
@Xaptik
Total: $1283.15
Wow. I didn't expect that big of a change while keeping that price. Impressive.
https://linustechtips.com/topic/551449-build-advice/#findComment-7276860
thank you
(bows) (walks off stage)
https://linustechtips.com/topic/551449-build-advice/#findComment-7276863
Does it really make that big of a difference?
Yes. It does.
Source: Have one
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/551449-build-advice/#findComment-7276868
and that mobo is just as good?
yep
there's almost no difference
https://linustechtips.com/topic/551449-build-advice/#findComment-7276880
4 minutes ago, Xaptik said:
Huh. Well then.
@shadowbyte and that mobo is just as good?
Actually, Jay mentioned in his latest video that the MSI Krait Edition has issues with overclocking. So there's that
https://linustechtips.com/topic/551449-build-advice/#findComment-7276891
that was in regard to the AMD 970A version. I love my Z97S Krait though. It looks great, has expansion, and houses all my hardware perfectly
https://linustechtips.com/topic/551449-build-advice/#findComment-7276902
Massive. You can start the computer in seconds, you can load things almost instantly...I'll never go back to an HDD based system. Actually, I've decided to never add an HDD to my system again. All future builds will be SSD only, with an external array for mass storage.
Older models, and only with AMD chips that are overclocked....not exactly the same thing.
https://linustechtips.com/topic/551449-build-advice/#findComment-7276903
So does just having an SDD for booting Windows speed up doing everything?
https://linustechtips.com/topic/551449-build-advice/#findComment-7276911
2 minutes ago, Xaptik said:
Another thing. I see SuperBiiz and Outlet PC on there. Are they pretty good dealers?
they're alright
if you consolidate the part list to just newegg, it's a bit more expensive, but all your components arrive at the same time
https://linustechtips.com/topic/551449-build-advice/#findComment-7276916
I bought a keyboard from Outlet PC a week ago. Great speedy shipping, very well packaged.
Anything stored on the SSD will boot faster. If Windows has to search your SSD for files during boot, it will slow down.
https://linustechtips.com/topic/551449-build-advice/#findComment-7276971
10 hours ago, Xaptik said:
So what should I install on an SSD?
Windows. Plus your favorite games, if you have space.
You need to make sure to move My Documents and My Pictures and such to the HDD, since windows will stick those on the disk it's installed on by default.
https://linustechtips.com/topic/551449-build-advice/#findComment-7279552
