Work in progress Build Help requested
1 hour ago, ShaunC said:I'd go with something along these lines
If you're planning to do upgrades, i would just suggest a slower processor and a good mobo that you can build off of. Also, if you can find a good power supply on sale, i'd work with that. Try to find a Motherboard, Case, and power supply that will fit you're ideal computer needs after upgrades.
CPU: Intel Pentium G4500 3.5GHz Dual-Core Processor ($84.89 @ OutletPC)
Motherboard: MSI Z170A Tomahawk AC ATX LGA1151 Motherboard ($149.99 @ Amazon)
Memory: Mushkin Blackline 8GB (1 x 8GB) DDR4-2400 Memory ($35.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive ($59.99 @ Newegg)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card ($99.99 @ Newegg)
Case: Raidmax Vortex ATX Mid Tower Case ($19.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($43.98 @ Newegg)
Total: $494.82
Generated by PCPartPicker 2016-02-19 16:13 EST-0500
That PSU is a definite nono if you plan on putting a real graficscard in there. Apart fromt he fact that the pentium will be to weak to push anything worth calling a GPU.
