Hi guys
I just build my new pc yesterday and i ran in to a problem.
i install Win10 64bit and i have 8GB of 1866RAM in my system but only 3.94 is in use and i change it to win7 64bit still same problem
MY CPU is an AMD X4 860K, motherborad is a gigabyte GA-F2A88XM-D3H and RAM im using is a kington hyperX fury 2 by 4 kit running at 1866.
i have tried to change the lanes but didnt work
https://linustechtips.com/topic/550798-ram-problem/
That moment when you choose the best color for dark theme users. CE76J13.png
Now on to your problem. That is odd, but it does detect you having 8gb right? Normal, installing an 64bit OS would fix that. I have no idea now.
https://linustechtips.com/topic/550798-ram-problem/#findComment-7270606
Omg where do you select this dark theme? It would save my eyes.
Edit: Okay I found it ....some button at the bottom hahaha Sweeet!!
Edited by tomoki
https://linustechtips.com/topic/550798-ram-problem/#findComment-7270656
2 hours ago, SlienceRain said:
8gb shoes on the os but 4096 show in bios
And you are supposed to have 16gigs? There's something wrong with RAM itself or something like iGPU is reserving rest.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/550798-ram-problem/#findComment-7271278
