My PC boots up and shutdown super slow nowadays. When booting, it stuck at the bios setup page for around 3 mins or so before moving on. But after the bios page, everything boot up perfectly fine. During shutdown, it takes forever for the PC to turn off. My monitor receives no signal whatsoever from the PC, yet my PC is still running and takes about 5 mins or so to shutdown by itself. Is there a way to fix this problem? What problem could it be?
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/
Update your BIOS, if you can. If that doesn't help, you may just have a slow HDD.
              PC Specs:
CPU: i7-5930K | Cooler: Corsair H100i GTX | GPU: GeForce GTX 980 Ti | Mobo: ASRock X99 Extreme4 | Memory: HyperX Fury Black 16GB | Storage: SeaGate 2TB & SanDisk 120GB SSD | Case: Fractal Design Define R4 w/ Window | PSU: EVGA SuperNova 750W Gold Cert | Monitors: (x2) Acer S220HQL | Keyboard: Razer Blackwidow Chroma | Mouse: Corsair M65 RGB |
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7268758
1) get an ssd :) 2) Make sure boot order has HDD/SSD first 3) enable fast boot 4) if none of that works update bios
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7268772
use crystaldiskinfo to see if your drive is dying
if it is, you need to replace it
if not you should do a clean install of windows
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7268819
I am having a similar problem with my rig.
Not so much the shutdown but the boot up.  My PC will post the get stuck at the windows boot icon for about 2-3 minutes but not all the time maybe 1 in 10 boots.  i'm running a M.2 Samsung 950 pro SSD with all the BIOS setting configured give me a fast post and boot and i have updated and flashed the BIOS multiple times but the problem is there.
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7268903
I do have a ssd and my boot order have set to ssd first and i have enable fast boot and my bios is the latest version am i out of options?
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7268947
how do i clean install windows? I am running on windows 10 and it wouldn't let me reset my PC. it says something like "there is a problem resetting your PC. No changes were made." My drive is perfectly fine though.
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7268961
great tutorial right here
http://www.howtogeek.com/224342/how-to-clean-install-windows-10/
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7269014
What's your system? (Most importantly motherboard, CPU, RAM and SSD)
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
https://linustechtips.com/topic/550623-slow-bootup-and-shutdown/#findComment-7270337
