My parents got this really old computer that barely works and uses windows xp. Booting it up takes forever and just about everything on that computer is slow and unbearable. I opened it up to see every speck covered in dust. Is there anything I can do to this computer to make it suitable for at least some light web browsing or something?
https://linustechtips.com/topic/549463-old-computer-help/
Depending on the hard drive interface, you might be able to get an SSD for it.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7255680
Leafblower can fix that dust problem.
cf727e6b7dfb5b4d5887f4a70e8665ff63968f05
If you want to just browse with it, then install Ubuntu.
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7255685
use CPU-Z ID and pull out the PC specs
i say it might be a P4 system using IDE drives
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7255717
3 minutes ago, InvertedGPR said:
Alright, I'll check out the specs and stuff tomorow, but it is extremely slow and I don't if I can get that far to be completely honest. And if I can get a hard drive for cheap I'll get one.
If it takes too long to boot, just jump into the bios on boot and copy the cpu/ram/hard drive (should have the product code/name likw WD1200 etc) down and post it for the guys here :3
I would start by getting some of the dust off, then consider your options (do you have money for replacement parts? Looking to just do a system sweep x clean? Will it be compatible with new OS's or will you want XP reloaded? (even though its outdated and no more security bug fixes))
And go from there!
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7256006
maybe a windows reinstall?
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7256148
And go from there!
I don't know if this is exactlt what you wanted, but here it is.
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7261192
I would be shocked if those old hard drives are still good; Grab DiskCheckup and check the SMART info and run some tests to be sure. While you're looking at the drives, pop open Device Manager and check that the transfer mode is Ultra DMA / UDMA of some description and not PIO under the IDE controllers' properties dialogs. I'd also check the motherboard for bad capacitors, since that's from right in around the time of the Capacitor Plague. And for good measure, it's always a good idea to run memtest86+ to make sure that old RAM is still OK.
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7261284
The problem with that is that it won't run Google Chrome and Internet Explorer won't work. So it's kind of hard to run anything
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7261364
17 minutes ago, InvertedGPR said:
Install Chrome through a usb?
Er... No. Memtest86+ and DiskCheckup. Though if you're saying that Windows is completely unable to load any programs, you'll probably need to burn a CD/DVD with a Linux distro or something on it in order to run tests from that instead. No sense in reinstalling Windows if the drive is failing after all.
https://linustechtips.com/topic/549463-old-computer-help/#findComment-7262436
