Hi everyone,
Can someone please suggest a system configuration best suited 3D graphics for a budget of around 4,500 $. I mainly do rendering in corona,octane,arion,Vray, lighting & composting and software i use is (3DS Max, Photoshop,unreal engine,realflow), hence my requirement is a system that reduces the render time to the possible minimum.
https://linustechtips.com/topic/548322-looking-for-best-system-configuration/
http://pcpartpicker.com/p/c3sjf7
something along these lines, you may want to get 2/3 980ti if you don`t want to spend that much and you can get a 5930K for less, really depends on your needs
to game or not to game, that`s the question
27 minutes ago, Nithin57 said:
Hi everyone,
Do you do cpu or gpu rendering?
If you use cpu, go dual xeon. If you do rendering on gpu them @UnlimitedTMDhas a good build.
For cpu rendering go with this
PCPartPicker part list: http://pcpartpicker.com/p/Cq7yvK
Price breakdown by merchant: http://pcpartpicker.com/p/Cq7yvK/by_merchant/
CPU: Intel Xeon E5-2670 V3 2.3GHz 12-Core OEM/Tray Processor  ($1434.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus Z10PE-D16 WS SSI EEB Dual-CPU LGA2011-3 Motherboard  ($495.99 @ SuperBiiz)
Memory: Crucial 32GB (4 x 8GB) Registered DDR4-2133 Memory  ($244.99 @ Adorama)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.89 @ OutletPC)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Operating System: Microsoft Windows 7 Professional SP1 OEM (64-bit)  ($142.88 @ OutletPC)
Other: Quadro k22-- ($429.99)
Total: $4508.46
Generated by PCPartPicker 2016-02-15 11:08 EST-0500
I also put a quadro in as they normally preform much better in apps like maya and 3ds max and are more reliable, and if your rendering on cpu you don't need a massive gpu.
Aren't Firepro's cheaper than Quadro's? And don't they perform just as well when they use OpenCL?
        Pixelbook Go i5 Pixel 4 XL
