Does the drive spin up?
https://linustechtips.com/topic/547763-sata-help/#findComment-7237739
Just now, Durzo_Blint99 said:
yes it appears to and it is getting warm like its functioning properly
Did the cable suffer any damage? Is everything connected properly to the drive and to the board(coming from the drive).
https://linustechtips.com/topic/547763-sata-help/#findComment-7237747
1 minute ago, Durzo_Blint99 said:
not that i can see and i did try and swap it for a brand new cable and still had the same problem
Did the board on the drive(if visible) suffer any damage?
https://linustechtips.com/topic/547763-sata-help/#findComment-7237766
no it never came out of the case and nothing was inside
Do you have any other hard drives you can connect to the system?
https://linustechtips.com/topic/547763-sata-help/#findComment-7237777
i do but it dosent have a sata port
How about another system to connect the drive to? Perhaps a friend's computer?
https://linustechtips.com/topic/547763-sata-help/#findComment-7237798
ok so after looking closely the power cable to the drive was halfway out and after un plugging it and plugging it in its working thanks for the help though
https://linustechtips.com/topic/547763-sata-help/#findComment-7237846
I did ask you that earlier if everything was connected properly to the drive.
https://linustechtips.com/topic/547763-sata-help/#findComment-7237856
lol no need to get smug it is dark in my case^_^
lol. As long as everything is working properly, that's what matters.
https://linustechtips.com/topic/547763-sata-help/#findComment-7237875
