Hey All,
I have a .csv file with reviews for hotels. I need to take each of those reviews, and put them into the same string. Then convert it to a dictionary of words and the count of each word. I got it to work for a twitter assignment but now it keeps giving a
TypeError                                 Traceback (most recent call last)
<ipython-input-1-dfe0abbe08b3> in <module>()
     13 for line in infile:
     14     print (line)
---> 15     text += line['text']
     16
     17 words = text.split()
TypeError: string indices must be integers
I don't know where I am going wrong because it worked in one way and not the other.
Here is my code
from collections import Counter
import csv
csvFile = open("FnLn-A2-Hotel1.csv", "a")
writer = csv.writer(csvFile)
text = ""
infile = open("HotelReviewSource.csv").readlines()
for line in infile:
#    print (line)
cleantext = ""
for word in words:
    cleantext += word + " "
wordcount={}
for word in cleantext.split():
    if word not in wordcount:
        wordcount[word] = 1
    else:
        wordcount[word] += 1
print (wordcount)
c= Counter(cleantext.split())
for word,count in c.most_common():
    print (word,count)
    writer.writerow ([word,count])
csvFile.close()
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/547759-more-python-help/
im not exactly sure what youre doing wrong because you didnt say what is going in and what you want out, but I know the problem is that "line[x]" returns the character which is in position x of the string "line"
for example if line is "hello" then line[2] will return "n"
so you cant have line['text'] because 'text' isnt a number, its a string
if you could give more info on what infile looks like and what you want lines 13-15 to output that would help :)
https://linustechtips.com/topic/547759-more-python-help/#findComment-7237722
Unless line is a dictionary , but it isn't here and it doesn't make any sense for it to be a dictonary.
Anyway, you should probably do this :
for line in infile:
    text.append(line)
Where text is a buffer ( vector of strings )
Or
text+=line
If you just want text to be a big string, but I don't see the point since you use split anyway.
https://linustechtips.com/topic/547759-more-python-help/#findComment-7237749
Sorry, the input from the source file is a list reviews. In cell A1 is a review for a hotel down to about A65 etc
I need the final output to be a counter of words and the number of times they show up.
the 67
best 54
hotel 18
when 65
etc
After 'text' becomes just one big long sting of all the reviews, the rest of the code should work.
for line in infile:
    text+=line
HOT DAMN! It worked!!
That was a HUGE thorn in my ass.
I think I want to put you on retainer for the rest of my semester haha
https://linustechtips.com/topic/547759-more-python-help/#findComment-7237789
the 67
best 54
hotel 18
when 65
etc
You know , errors are supposed to tell you what's wrong.
And here you had :
At
Which is pretty self-explanatory.
Anyway , good luck for the rest of your semester.
https://linustechtips.com/topic/547759-more-python-help/#findComment-7237806
And here you had :
At
The class is not really a coding class so much as it is data analysis. The professor just glosses over the coding aspect of it, but I'm making out a bit better than the rest which is not great..
https://linustechtips.com/topic/547759-more-python-help/#findComment-7237834
