Ok so I want to know is there a product out there that will disperse the heat from my pc to my freezing cold room. The heat doesn't work in my two story house the main floor is well heated but my gaming room isn't.  so if i get my pc to 80-90 degrees while gaming can I spread that heat to my room making it 80 degrees and not my pc. Just wondering because that would be cool. I thought of this while watching Linus's video about water cooling a whole room and i thought what if i heated my room with my pc. I think it would be really cool.
https://linustechtips.com/topic/547713-pc-heater/
Your fans should do that.
the one and only job of an exhaust fan is to get hot air out of your pc
play some games, stress testing and thats really the only way you could get a room with a pc that I know of
Longboarders/ skaters message me!
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237239
stick a box fan next to it?
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237242
Yes there is something, it's called exhaust fans
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237243
just let it run, mine runs at 30-40 degrees and it warms my room allot! it's nice
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237249
2 minutes ago, Vladipiggy said:
thanks for the replies i haven't set up my pc yet I am waiting for all my parts to arrive i am upgrading from a crappy laptop to a gaming pc and i had no clue if this would actually do much thanks for the replies
the laptop will work even better if you run aida64 on it or something? haha you'll probably be able to bake an egg on there... yes :P
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237270
I cant actually use my laptop anymore as it's battery failed and will not even work anymore it wont charge but its not a cord problem... it had a dual core celeron so im not complaining about a brand new i5 and gtx 750 ti
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237290
The better your computers cooling the warmer your room will be.
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237296
Unless that room is very small, a single PC won't be enough to heat it up to a comfortable living temperature.
You're better off just getting a space heater that consume between 300w to 600w on the lowest setting and leave it on in the room.
Either that or some older computers that you leave ON all the time while running prime95 or something on it.
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237341
5 minutes ago, Vladipiggy said:
Shoot my budget build only allowed me to use the stock cooler but im saving up for a watercooling upgrade
Water cooling will do fine at dispersing the heat.
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237346
Oh yeah my gaming room is super small, harry potter would turn down my room because of size
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237355
Actually water cooling will disperse less heat, since the point is to be absorbed by the water and the fans run quieter and at less RPM, if you had a regular exhaust fan pumping out air at full speed it would heat a room way easier.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237380
I was debating whether to say that, but once the water has heated up won't it be just as effective as air, given that there are fans blowing at their max on the radiator.
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237396
Think of it like this, water is far more efficient at absorbing heat then the heat pipes and metal contact points. This is why when looking at water cooling loops you can achieve far lower temperatures with the fans spinning with significantly less RPM. Water is just plain more efficient at dispersing heat the surface area is pretty much spread out and the heat is dispersed evenly.
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237411
Water is very good at dispersing heat, a 140XL on my FX-9590 gets my 2x2m room heated in half an hour, in some ways, I'm not looking forward to my new room.
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237446
You should have your computer fold flr F@H that way you heat your room and help fight disease
LOOK AT MY NEW FLAG DESIGNS FOR PA AND VOTE ON YOUR FAVORITE
LOOK AT MY FIRST BATCH OF DESIGNS HERE
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Cooler Master Seidon 240m
EVGA SuperNOVA 650 G1
Kingston 120gb SSD
SanDisk 480Gb SSD
Seagate 1Tb Hard drive
https://linustechtips.com/topic/547713-pc-heater/#findComment-7237597
