Powerline Ethernet Adapter help
Please please please... Call this powerline not power over ethernet. "Power over ethernet" means you deliver power via ethernet cables, usually to an AP or camera. Powerline is the opposite, it is ethernet over power.
1) yes that's a pretty good set, but note that it's called Powerline not PoE
2)Powerline is too unpredictable to be able to say before you try it out. At the very least it will give you another option in addition to wireless when everyone is home
3) go to the circuit breaker in your house and figure out which breaker controls each of the outlets you want to put an adaptor on (i.e. The outlet near your computer, and the one near your router). See what row they are on in the breaker panel. Every even row is in phase 1, and every odd row is in phase 2. Powerline adaptors can only talk at full speed to adaptors on the same phase. Models that are "Powerline AV2" like the ones you linked can also communicate using the ground wire, rather than just the hot and neutral wires, so if the outlets if the house have a common ground despite being in opposite phases, you should still be able to get a little bit of a connection (most houses are wired with only one common ground)
