Your Wifi card should get enough power from the 1x slot. And yep, pretty much most motherboards have PCIe slots now.
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
the power supply in this build is a non modular one http://pcpartpicker.com/p/1BI5R. Do u know which is better?? Modular or a non modular PSU??. The non modular one looks good too.
That is up to you to decide. Modular PSUs are basically only plug the wires you need into the PSU. It helps with cable management and gives you less clutter. A non-modular PSU has all the cables coming out the PSU. It means you'll have to put all the cables somewhere.
I would also say you should grab the 7950 over the 760. Or you can wait and see how the 9000 series AMD cards are like for performance.
But the modular PSU i chose has enough cables for my whole build right?? Yeah I'm still considering which card I should grab.
Yes it should. It's all up to what you want to get though.
