I am 17 years old and I have not build a PC before I'm trying to build one but I'm not sure if I assembled my parts correctly. I do not wish to spent more than $1000. I live in Singapore BTW.
Here are the parts:
CPU: Intel i7 2600k or i5 3570k
CPU Cooler: Cooler Master Hyper 212 Plus
Motherboard: MSI Z77A-G45
Memory: 8GB (2 x 4GB)  G.Skill Ares DDR3-1866 Memory
Storage: Samsung 840 Series 120 GB 2.5'' SSD
               Seagate Barracuda 2TB 3.5'' 7200RPM Internal Hard Drive
GPU: ASUS GeForce GTX 760 DirectCU II
Wireless Network Adapter: ASUS PCE-N15 802.11b/g/n  PCI Express X1 Wi-Fi Adapter
Case: Cooler Master 431 Plus ATX Mid Tower Case
PSU: Corsair CX 600 M  Power Supply
Optical Drive: ASUS DRW-24B1ST/BLK/B/AS DVD/CD Writer
Here's the link: http://pcpartpicker.com/p/1BHif (Not sure if its correct)
Since this is the first time I am building a PC I want to make sure everything is set up correctly. After watching Linus's build guide I am still a little confused. I am not sure if the Power supply has enough cables for my build. I'm a little new to building a PC that is why I need your help. Any recommendations,suggestions and tips u want to give me I'm more than happy to take. Thanks.
https://linustechtips.com/topic/54680-first-pc-build-need-help/
What things are you not too sure about?
Everything in your list works with each other fine. You might want to reduce the speed of the Ram down to 1600 Mhz because there isn't much difference between 1866 and 1600. Use that money somewhere else.
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734793
It usually helps when you tell the community what budget you're on and what you intend to do with the computer.
looks fine to me.
Grammar nazis are people too!
Treat your local grammar nazi nicely and he might teach you a thing or two. (Note that I'm Belgian and not a native English speaker.)
Chivalry isn't dead!
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734795
I'm building this as I am transferring from console to PC. I heard that a PC has a overall better performance than the consoles. I'm not sure if the PSU has enough cables for my Motherboard,GPU and the wireless adapter. The power supply Linus use in the $1500 build guides has more cables. However' it is more expensive. I wonder if this build guide has enough cables for the entire build?
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734811
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734818
looks fine to me.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734822
Good to hear you're coming over to the light side, yes we do have better (gaming) performance.
Be advised that the new AMD graphics cards are coming out and will offer superior performance, it might be worth the wait but it's your call.
For the PSU cables, I'll look into it when I have more time, unless someone beats me to it.
Feel free to PM me if I happen to forget all about it.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734829
yeah, there is no i7 3570k. and what do you need the wireless card for?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734845
From what it looks like you'll be using all your SATA power connectors. One for the SSD, one for the HDD and one for the CD Drive. I think it should be just about fine.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734853
sorry my bad i5-3570K. my wired router is outside my room and its too far away. that's why I need the wireless card
look at the nzxt source 210 case. you may like it.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734856
alright! thanks for the help and advice :) maybe i'll wait for a while im not in a rush. im probably building at November this year.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734859
AMD 9000 series may be out by then. prices will change.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734863
what about the wireless adapter? does my motherboard have a PCI Express X1 slot?
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734868
yes.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734879
I"ve never been paying attention to the AMD cards. I did most of the research on the Nvidia cards. If the 9000 series comes out at that time the prices may be more expensive.
AMD cards are good. and AMD releasing new cards may lower prices on existing cards.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734885
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734912
are AMD processors good?? I'm more into intel processors. ( sorry if I ask too much questions)
yes they are good and you also dropped the prices and got better PSU and case. if you want you can get the fx8350
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734941
the PSU u chose is non modular. What's the difference between a modular and a non modular PSU??
you can unplug cables that you won't use.
https://linustechtips.com/topic/54680-first-pc-build-need-help/#findComment-734997
