Posted February 13, 2016 What ratings/grades are best? and why? And which one would benefit as a 650PSU Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 2 minutes ago, ZeusXI said: What ratings/grades are best? and why? And which one would benefit as a 650PSU Titanium is the best, but for a 650W you can look for bronze, gold or platinum depending on the rest of you system. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227442 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 NEW PC build: Blank Heaven minimalist white and black PC Old S340 build log "White Heaven" The "LIGHTCANON" flashlight build log Project AntiRoll (prototype) Custom speaker project Spoiler Ryzen 3950X | AMD Vega Frontier Edition | ASUS X570 Pro WS | Corsair Vengeance LPX 64GB | NZXT H500 | Seasonic Prime Fanless TX-700 | Custom loop | Coolermaster SK630 White | Logitech MX Master 2S | Samsung 980 Pro 1TB + 970 Pro 512GB | Samsung 58" 4k TV | Scarlett 2i4 | 2x AT2020 Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227444 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author Just now, Wouterrinos said: Titanium is the best, but for a 650W you can look for bronze, gold or platinum depending on the rest of you system. I7-4790k GTX 960 4GB 250GB SSD 1TB Blue 7200Rpm 1TB Blue 7200Rpm (These Raid 0) ATX motherboard. and Midtower ATX case With all components in it, runs about 320Watts on Load Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227448 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 12 minutes ago, ZeusXI said: I7-4790k GTX 960 4GB 250GB SSD 1TB Blue 7200Rpm 1TB Blue 7200Rpm (These Raid 0) ATX motherboard. and Midtower ATX case With all components in it, runs about 320Watts on Load https://pcpartpicker.com/part/evga-power-supply-220gs0550v1 Is good enough, 650 is a bit to much. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227495 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author 1 minute ago, Wouterrinos said: https://pcpartpicker.com/part/evga-power-supply-220gs0550v1 Is good enough, 650 is a bit to much. Alright Thank you! and would this bring expansion to GPU? im thinking GTX 960 4GB Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227510 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 1 minute ago, ZeusXI said: Alright Thank you! and would this bring expansion to GPU? im thinking GTX 960 4GB 550W is enough for i7-4790k and one 960 without big AIO. If you meant a second 960, you'll need the 650W version. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227545 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author Just now, Wouterrinos said: 550W is enough for i7-4790k and one 960 without big AIO. If you meant a second 960, you'll need the 650W version. What do you mean by AIO? Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227547 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Just now, ZeusXI said: What do you mean by AIO? A All In One liquid cpu cooler, but seeing the load, I'm assuming you don't have one of those. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227559 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author Just now, Wouterrinos said: A All In One liquid cpu cooler, but seeing the load, I'm assuming you don't have one of those. My friend gave me a dual Radiator. http://www.newegg.com/Product/Product.aspx?Item=N82E16835220081&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-BD%20Industries%20LLC-_-na-_-na-_-na&cm_sp=&AID=10440897&PID=7718204&SID=pchound one of those. it was in box when he gave it to me. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227567 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 8 minutes ago, ZeusXI said: My friend gave me a dual Radiator. http://www.newegg.com/Product/Product.aspx?Item=N82E16835220081&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-BD%20Industries%20LLC-_-na-_-na-_-na&cm_sp=&AID=10440897&PID=7718204&SID=pchound one of those. it was in box when he gave it to me. shouldn't be a problem. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227620 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author Just now, Wouterrinos said: shouldn't be a problem. THANK YOU!! Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227624 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 2 minutes ago, ZeusXI said: THANK YOU!! Still, I didn't get if you haven't got the 960 and plan getting one or already have one and want a second one? Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227641 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author 2 minutes ago, Wouterrinos said: Still, I didn't get if you haven't got the 960 and plan getting one or already have one and want a second one? Oh sorry. Im really using the 960 as an example, but I honestly might consider moving from a GTX 750 Ti 2GB and going to a 960 when AMD Polaris, and Nvidia Picasso come out. then GPU prices should go down maybe. But i put the GTX 960 in, because the power consumption so I have some le-way to build a rig and have enough power to use the hardware. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227664 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Just now, ZeusXI said: Oh sorry. Im really using the 960 as an example, but I honestly might consider moving from a GTX 750 Ti 2GB and going to a 960 when AMD Polaris, and Nvidia Picasso come out. then GPU prices should go down maybe. But i put the GTX 960 in, because the power consumption so I have some le-way to build a rig and have enough power to use the hardware. Ahhhh Okay, well the 550W will be plenty then. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227677 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 Author 2 minutes ago, Wouterrinos said: Still, I didn't get if you haven't got the 960 and plan getting one or already have one and want a second one? Oh sorry. Im really using the 960 as an example, but I honestly might consider moving from a GTX 750 Ti 2GB and going to a 960 when AMD Polaris, and Nvidia Picasso come out. then GPU prices should go down maybe. But i put the GTX 960 in, because the power consumption so I have some le-way to build a rig and have enough power to use the hardware. Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227679 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 13, 2016 @ZeusXI Why u repeate ur self, why u do this !!! Link to comment https://linustechtips.com/topic/546675-psu-efficiency-help/#findComment-7227701 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
