2 minutes ago, Marcus Torre DeProspero said:
I know Noctua makes great fans but I'm not really into them. I want to know if there are any other fans that would be good as case fans I need three for my case. I also need three static pressure fans for mu y aio cooler.
noctua for the pressure
other than that, i like the corsair quiet series
ive got 6 blue led ones running in my system
https://linustechtips.com/topic/546564-quiet-performance-fans/#findComment-7226196
Corsair makes good fans like their SP120 or you could try Fractal or EK's Vardar fans.
Main: AMD Ryzen 1600x | Custom Loop | Gigabyte Aorus X370 Gaming K5 | EVGA GTX 1070 Hybrid | Corsair 400C | 32GB (4X8GB) Corsair Vengeance Black DDR4 | Seasonic X-650 PSU | Samsung 960 EVO 256GB | Intel 520 240GB | Seagate Firecuda 1TB SSHD | Windows 10 Pro | LG 25UM58-P | Asus VS247H-P | Corsair Ironclaw RGB Mouse | Corsair Strafe Keyboard
https://linustechtips.com/topic/546564-quiet-performance-fans/#findComment-7226198
I'm using the AF120  fans from Corsair and they're actually pretty quiet and effective.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/546564-quiet-performance-fans/#findComment-7226221
Fractal designs venturi series have great air flow and are very quiet(especially if you use the low noise adaptor)
CPU: Intel I5 4690K | GPU: Asus R9 280x | PSU: Evga 600w | RAM:8GB DDR3 | HDD: WD 1TB | HDD: WD 500GB | SSD: Sandisk 120GB
https://linustechtips.com/topic/546564-quiet-performance-fans/#findComment-7226252
Where are you shopping/located? Budget? Where are the fans being placed?
https://linustechtips.com/topic/546564-quiet-performance-fans/#findComment-7227709
