So I am trying to use a decent lapel mic I have for recording audio. I currently have it plugged into my computer via a 3.5 audio to XLR cable. The sound often becomes faint or glassy and I am not sure how to fix this. I am recording with audacity. I was thinking that a USB to XLR might work but am not sure what the best place to find this is. I would love a small  USB sound board but these get expensive and aren't small enough for my desk.
https://linustechtips.com/topic/545830-solution-for-microphone-problems/
uh, you do not use a USB to XLR cable for a mic..
you use an audio interface
What lapel mic has a xlr out.
The Dick of the audio page!
1 minute ago, Sudo Chocolate said:
That is what I am currently using however is causes the problems I described. There is also static.
what exactly are you using then
you said you were using a XLR to USB cable
you should be using something like this
I am currently using an XLR to 3.5mm audio. I want something external that converts it to USB so as to avoid static. The picture is kind of what I am looking for but want suggestions that are fairly low price and pretty small so it can fit easily on my small desk.
