I need help.
JohnF03
Alright, I have two pair of headsets. One is my Sennheiser HD 219 (No mic), and a Logitech H390 (with mic). The problem is, the Logitech uses USB, and I want to use my sennheiser as my primary listening device, and only the mic from logitech. How do I do this?
change which one is default in the windows sound settings
If your H390s have a USB interface, you can probably just disable the sound output to them in the Playback tab in the Sound window. Then enable the mic in the Recording tab and disable other recording sources listed there, and then enable whatever interface you're using to drive your Sennheisers on the playback tab.
