Hello.
I mainly want to play video games and maybe do some live streaming for fun for my friends.  I wish to play all the new games at 60+ fps. My budget is 1000$, this is as high as I can go. ATM I have a 1080p monitor.
I tried to build one myself but idk if it's any good. http://pcpartpicker.com/p/TwkcWZ
Hope you guys can share your opinion with me and make the best out of those 1000$.
(sorry for my bad englando)
Greetings from Romania,
-Alexandru
https://linustechtips.com/topic/544758-help-me-build-my-first-pc/
As usual switch the CX for almost anything EVGA, Antec or Seasonic.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
15 minutes ago, revo said:
Hello.
-Alexandru
http://pcpartpicker.com/p/t7MnZL
it's 22 dollars over budget, hope that this won't be a big problem.
-SSD is a must as I see it, why wouldn't you get an SSD.
-If you go k-series cpu get an z170 mbo for overclocking
-hyper 212 can be switched out if you want to do more overclocking but that isn't in budget.
1 minute ago, revo said:
On this PC I have a corsair PSU and I've never had any problem with it. And in my country I can't find any good PSU for a good price. They are out of stock or just over priced, so if you guys are cool with the CX I will stick it the CX.
I've no problems with cx, but go with semi-modular or full if you can.
And the case you choose isn't available, whatsup with that? you already have it?
13 minutes ago, ArmswieldTheHero said:
It looks great to me, never had any experience with corsair power supplies, but I hear rosewill and evga make good ones. You might wanna invest in an SSD, its only 90 dollars for a good 250GB model.
An SSD can and will improve performance. If you can get a mechanical hard drive for storage.
3 minutes ago, Wouterrinos said:
Ok great, only thing I would change in my build is the cpu cooler for a h80i GT, but it's a bit more expensive, but it looks and performs great though.
I wish I could but it's over the budget. Do you think that the curent CPU cooler can fit in that case?
4 minutes ago, Wouterrinos said:
your case is 192mm wide and the 212 is 152mm high so with the mbo( maybe 5mm) it should be no problem.
Awesome. Is there anything there that I need to change? If not. I'm gonna order this build this week. Thank you for your support.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.95 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($124.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($69.89 @ SuperBiiz)
Storage: OCZ Trion 100 240GB 2.5" Solid State Drive  ($65.89 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.88 @ OutletPC)
Case: NZXT S340 (White) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ NCIX US)
Total: $1011.97
Generated by PCPartPicker 2016-02-09 20:45 EST-0500
You can go for a 970 if you want, it has more horsepower for a 1080p gaming setup, but the r9 390 is a good option if you want to go later on for 1440p or anything like that, you can change these to your liking.
Total: $1011.97
This is a really nice build but in my country most of these items are really hard to find or just very overpriced, so I'm gonna stick with the curent build ( http://pcpartpicker.com/p/t7MnZL ). Thank you so much for your help anyway.
that's not bad.. i'm happy :)
