So as many of you know, I am planning on doing a passively cooled PC. I plan to use an r9 nano unless I cannot sell my existing GPU.
With a 3930k and r9 nano, are there any passive PSUs that could power the build or should I just continue to use my overkill 750W G2? I would like a smaller one because... I really do not need 750W for a machine with a rated TDP of less than half of that.
https://linustechtips.com/topic/544428-small-fanless-psus/
4 minutes ago, DEcobra11 said:
Super Flower SF-500P14FG
That supply certainly looks promising
But where can I buy the damn thing?
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7202096
2 minutes ago, itsmyjobtoknow said:
Seasonic SS-XX0FL PSU
The XX I put there to represent the various watt such as are avilable 520, 460, and 400.
OH thats expensive........... I bet the superflower one is just as bad, if not more
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7202123
Probably...but remember that these PSU must have HIGH-Quality component in order for it to be able to be passively cooled.
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7202131
Oh ya I know, the higher the efficiancy, the lower the heat output. I guess they are a somewhat niche application though, thus why they are a bit spendy
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7202138
I mean you can go the other route where you buy an extremely high wattage PSU with hybrid mode.
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7202185
1 minute ago, turkey3_scratch said:
Can't get better than the Silverstone Nighjar 520W.
Why would something that exists in 2016 still not use the standard black paint???
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7203269
It's not like matte black is a requirement. White PSU will look nice in white case.
That one aint even white, its the old style silver from like 1000 years ago
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7203290
Just now, turkey3_scratch said:
No, not quite, it's not old silver, it has a white paint, or should I say close-to-white. Is there something wrong with light grey? I kind of like it :P
The first one I found on amazon looks like the old silver. The PSU will be pretty external to the case, so I want it to look nice. I could always paint it...
https://linustechtips.com/topic/544428-small-fanless-psus/#findComment-7203318
