You can always mod the cooler but i think Enermax is only truly white cooler including the fan and heat sink.
Magical Pineapples
https://linustechtips.com/topic/544282-white-cooler/#findComment-7200566
The Phanteks PH-TC12DX White is also white (as the name implies), idk if this is in your price range or if it is available in slovakia but it is in the netherlands.
EDIT: the Phanteks PH-TC14PE White could also be an option.
Someone once said: "Having a rollercoaster on a PC would be epic"
So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build
https://linustechtips.com/topic/544282-white-cooler/#findComment-7200606
The T40 has been sadly phased out for the T40F which doesn't look as nice.
Aside from what @tomaatvk mentioned, those are the only coolers I can think of with a nice white heatsink atm.
https://linustechtips.com/topic/544282-white-cooler/#findComment-7202562
