Hey guys, I'm back! So I just recently got into building pc's and my first one went smoothly and worked great until today. I tried to open battlefront and it gave me an error message and told me to update my graphics drivers.... and..... like and idiot... I installed the wrong drivers for my graphics card. My screen went blank and I can't fix it. I have the Asus strix  gtx 960 if that helps. I also have a really old video card that will work  for a few minutes before my computer restarts on it's  own. What should I do?
https://linustechtips.com/topic/544060-help/
If your cpu has a built in gpu, plug into that, boot up, remove the driver, use nVidia geforce experience to make sure you always get the right driver, boot down, switch to your gpu again, boot up again.
https://linustechtips.com/topic/544060-help/#findComment-7197859
you need to get g force experience so it will install the right drivers instantly.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/544060-help/#findComment-7197910
