SO there is three answers...
One leg of a right triangle is 1 millimeter longer than the shorterleg and the hypotenuse is 2 millimeter longer than the shorter Find the lengths of the sides of the triangle.
The length of the shorter leg is 3mm
The length of the longer leg is____
The length of the hypotenuse is ____
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/543944-math-help/
16 minutes ago, Nup said:
Four and five.
That was it. Thanks!
Main Rig
Plex Server WIP
https://linustechtips.com/topic/543944-math-help/#findComment-7196599
For the future use the Pythagorean Theorem:  a^2 + b^2 = c^2 ,
A really fast way to find the third side or check if it's a right angle (other than the Pythagorean Theorem) is pythagorean triples. There's a few of them and they are a set of three numbers that always make a right triangle. Their multiples also make right triangles. Here are a few  Pythagorean triples (3, 4, 5) (5, 12, 13) 8, 15, 17) (7, 24, 25) (20, 21, 29) (12, 35, 37)  (9, 40, 41) (28, 45, 53)  (11, 60, 61) (16, 63, 65) (33, 56, 65) (48, 55, 73) (13, 84, 85) (36, 77, 85) (39, 80, 89) (65, 72, 97)
https://linustechtips.com/topic/543944-math-help/#findComment-7196963
