will this work for bf3
title should say it all
Creative Sound Blaster SB1040 X-FI
http://www.amazon.com/Creative-SB1040-Sound-Blaster-Xtreme/dp/B000W7PNZI
just wondering im just getting it just to play bf3 honestly before this i have never been very compelled too use anything but onboard hd audio
never really needed the power as i output too a ht receiver for playback
https://linustechtips.com/topic/54374-will-this-work-for-bf3/
yeah would just work fine
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/54374-will-this-work-for-bf3/#findComment-730416
if you're using HDMI/optical/coax to a receiver don't bother with a sound card.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/54374-will-this-work-for-bf3/#findComment-731323
https://linustechtips.com/topic/54374-will-this-work-for-bf3/#findComment-733116
sound is sound, so yes.
For all the falsely accused: message me and we can decide how to right all the wrongs that happened to you!
I'm looking at the major corporations, the lying online communities, the government that protects us...
We are HUMANS, not robotic slaves!
https://linustechtips.com/topic/54374-will-this-work-for-bf3/#findComment-733189
