Need Better Fans
Go to solution Solved by WoodenMarker,
4 hours ago, JevCWatson said:
well i didnt really have a set budget but i would say around $170 for 3 fans would be a good budget for me
Well, it money isn't really an issue, Silent Wings 2's or NF-A14's would be among the best of options.
SW2's for quieter operation or A14's for better performance.
i just purchased the air 540 case from corsair and when i turned the computer on for the first time i noticed how loud the stock fans in the case were.
any suggestions on good quiet 140mm fans to use in this case?
Just because something doesn’t do what you planned it to do doesn’t mean it’s useless. – Thomas Edison
https://linustechtips.com/topic/542141-need-better-fans/
If you have the money, try getting Noctua fans. They are expensive but are good and quiet. If you can't spare the money, get the Fractal Design Venturi fans. They're not as good as the Noctua ones but still an excellent choice.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
https://linustechtips.com/topic/542141-need-better-fans/#findComment-7175745
Budget?
https://linustechtips.com/topic/542141-need-better-fans/#findComment-7177787
On 6/2/2016 at 0:14 AM, WoodenMarker said:
Budget?
https://linustechtips.com/topic/542141-need-better-fans/#findComment-7200998
https://linustechtips.com/topic/542141-need-better-fans/#findComment-7202475
