below 62C is safe
https://linustechtips.com/topic/540465-cpu-temp-help/#findComment-7157882
13 minutes ago, Rev:) said:
I was contributing to the Linus tech tips folding at home team when my cpu reached 60 degrees c and i cooled it down now to  38 c but i was wondering at what temp will fry my cpu it is a amd fx with a nepton cooler on it.
A quick search told me that you should be fine. Get to 65 C first and then we can think about it being a problem.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/540465-cpu-temp-help/#findComment-7157983
7 minutes ago, Rob200088 said:
You can search for TJ MAX this is the max temp for your cpu. If this temp is reached your pc will automatically shutdown.
Be careful what you read though - there is only one temperature reported for the 4770k on the official intel site (for example), and it's not TJmax
https://linustechtips.com/topic/540465-cpu-temp-help/#findComment-7157998
I'd say 75-80c+ is where you might want to become concerned, but 50's and 60's is completely normal.
Core i7 5820k 4.0Ghz (all 6 cores, Noctua NH-D15) | Asus X99-Deluxe | ZOTAC GeForce 980 Ti (water cooled) @ 1400 core/stock VRAM | Corsair Vengeance 32GB DDR4 | 1.5TB SSD | Corsair 400Q | eVGA Supernova G2 850 watt | Dell UltraSharp U2515H, 25.5" 1440p IPS
https://linustechtips.com/topic/540465-cpu-temp-help/#findComment-7158990
