Hi everyone, I've tried to set up an old PC that i found in garage and i would like to give away to a friend, but i've to configure this (i mean installing OS). I know how to do that but I don't know why i can't enter even to the BIOS for start running the PC from a DVD, it just hold on the same screen about the CPU and don't do anything. (i've tried to leave on power for days).
Here i've posted some photos, hoping that someone could help me :D http://imgur.com/a/UzocV
https://linustechtips.com/topic/539582-need-help-i-cant-setup-my-pc/
So its stuck on the boot screen (the last pic in your list?)
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
What happens when you press the delete key?
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
yes and if i press del to enter setup it don't do nothing
Try clearing CMOS, remove CMOS battery and leave for 10 minutes, long shot but may let you boot... Make sure keyboard it connected properly... try USB keyboard AND PS/2 if no joy...
Ok, this evening I'll try to do and let you know if it works :D Thanks
