CPU only watercool plan for Arc Midi R2 - Am I overspending? Do I have everything?
1) Yes all those parts are compatible and would work together.
2) With Z87 the price of motherboards make little difference in the over clocking capability, if you want more features then you should go for a higher priced board though. This is more of a question for the NB&P section of the forum though, you would get a much more detailed response.
3) Fan grills are useful with fans outside the case to stop small things falling into the fans and smashing the blades. They are mostly used when fans are mounted outside the case but can also be used for aesthetics or if you have exposed fans at the bottom of your case where something could drop into them. They can also protecty radiator fins from being dented if something falls on them.
4) Not really a question?
5) Dyes can stain your components and many people will tell you that they can clog your blocks but thats rare and it's usually not the dye thaty causes the issue. At any rate using a clear coolant with coloured tubing is usually the easier option.
6) You are in fact spending too little. Most notably on the pump where you should be looking at a Laing DDC or D5 pump.
7) You should test if all you components are DOA or not before setting up your loop, it will save you a lot of time if they turn out to be DOA.
8) Don't bother putting the GPU in; keep it safe. You can also leave power wiring until you set-up your loop.
9) A funnel is always helpful. A scalpel is much better for cutting than scissors.
P.S.: You can buy a 240 fan grill instead of two 120 fan grills.
