I just got an Intel REDS2CV360 (36 port sas expander). I already had an LSI 9211-8i.
The controller card was flashed to HBA mode a long time ago, when I first got it.
Is there anything special I have to do to have them work together?
I hooked them up together and I don't see my drives anymore. I'm beginning to wonder if the cables i ordered the other week to connect the card to the expander were the right ones.... (so i'm looking into that).
Besides the cables... anything I am missing?
Can Anybody Link A Virtual Machine while I go download some RAM?
https://linustechtips.com/topic/538782-sas-expander-help/
No, it should be plug and play. You have two SAS cables out from your RAID card feeding into the SAS expander. The rest of the ports are your outputs. You have power (the Molex) going into the SAS expander right?
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7141269
I have the RES2CV240 on a LSI 9271-8i - was just plug n play
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7142037
yes I used the power cable that was in the box... should I use the molex power directly from the PSU?
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7142314
It should work either way...I would try the molex from the PSU. Also try using the SAS cables that the expander comes with just to make sure it isn't your SAS cables.
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7142515
I couldnt use the ones that came with it because they were too short... but I'll see what I can come up with.. the seller I got them from on amazon hasnt responded if they were forward cables or not.
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7142695
Ah, I see. Yeah, the cables should work though. I would try the ones it comes with though, even if you have to leave the sas expander hanging in your case just to temp test it. It would be strange if your expander came dead on arrival though.
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7142920
Connecting to my backplane, I misordered my sas cables and found out I needed forward cables, but this was going from SFF 8087 to sata. Going from SFF to SFF, it shouldn't matter since the technology is designed to function a certain way.
Unless going from the expander > backplane (or drives) you need a breakout cable, then it does matter.
https://linustechtips.com/topic/538782-sas-expander-help/#findComment-7142985
