Hi, i`m just looking for some opinions on this pc im building, it would be the first pc i build, i havent decide if i should pick Skylake or Haswell E , and i relly dont know too much about pc`s , i just been reding a lot of guides and reviews of differents parst and stuff like that and this is what i put together so far:
http://pcpartpicker.com/p/XZKxXL
                             or
http://pcpartpicker.com/p/h7Hncf
What do you guys think?
https://linustechtips.com/topic/538687-first-build-some-opinions/
You are way into GTX 980Ti territory with that budget.
$1775:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($31.99 @ NCIX US)
Motherboard: Gigabyte GA-X99-UD3P (rev. 1.0) ATX LGA2011-3 Motherboard  ($153.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-3000 Memory  ($99.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($121.89 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($639.99 @ Amazon)
Case: Phanteks Enthoo Pro M Acrylic ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: EVGA 850W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($87.95 @ OutletPC)
Case Fan: NZXT RF-FN142-RB 50.0 CFM 140mm  Fan  ($6.99 @ Directron)
Total: $1724.64
Generated by PCPartPicker 2016-02-01 02:09 EST-0500
1 minute ago, Slim96 said:
Yeah,  which one you think would be better? i would be just straitgh gaming, and i would like some "future proof" or somethign i know would work for the next couple years.
The one I linked =P
If it is just gaming you can do Skylake.
it wasn`t showing... xD
$1668, support SLI for later on:
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($329.99 @ Newegg)  <<This will overclock when you need it to, a few years from now.
Motherboard: MSI Z170A GAMING PRO ATX LGA1151 Motherboard  ($112.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($89.99 @ Newegg)
Total: $1628.64
Generated by PCPartPicker 2016-02-01 02:15 EST-0500
:D
Hi, if your RIG is mainly for gaming, there is no reason for you to get an i7.
and that motherboard that you choose is simply overpriced.
http://pcpartpicker.com/p/NHxdsY
this is what i suggest. msi is now doing a promotion. FREE RAINBOW SIX SIEGE game with that motherboard.
and you should invest more into your graphic card as an i5 6600k will be a beast for you.
and i have also picked an aio liquid cooler for you in case you want to overclock it.
also like linus and many other tech reviewers says. the only thing that you can future proof, is your case and the powersupply. others, new things will just keep coming. for your budget, a 980ti is really the way to go.
CPU i7-6700k Motherboard MSI Z170A GAMING M5 RAM KINGSTON HYPERX FURY 2X4GB GPU ZOTAC GEFORCE GTX970 AMP! EXTREME CORE EDITION Case COUGAR ATX Storage WESTERN DIGITAL BLUE 1TB PSU CORSAIR RM650X Display(s) AOC G2460PQU 24" Cooling COOLER MASTER HYPER 103 CPU COOLER Keyboard CORSAIR STRAFE RGB Mouse CORSAIR M65 RGB Sound MICROLAB FC360/RAZER KRAKEN 7.1 CHROMA/AUDIO TECHNICA M50X Operating System WINDOWS 7 ULTIMATE
So just gaming then? What's your display set up?
