Whenever I attempt to go to Imgur, the first time it tells me that connection has been timed out (or something like that) then if I refresh it the page is white and there is hypelinked text all over, then when I refresh it AGAIN, I see the normal imgur layout but the pictures take ages to load.
Browsing reddit (/r/flying) but I cannot like, look at anything because it takes a lot of time to load anything, my internet is working fine in Youtube albeit I am getting slightly more 'error has occured' on a video, I can also listen to spotify with no problem.
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/538413-imgur-does-not-want-to-load/
try ipconfig /flushdns in CMD and clear cache and cookies of your browser
Did that and it didint work
7 minutes ago, Marshall212 said:
Try and reset the internet by disconnecting the modem/router from power for 20 seconds. Reconnect it and see what happens?
Will try that when I have time as I am nto the only one using hte internet.
My PC:
I've been having nothing but issues with any images loading from imgur with images taking an age to load even though I have an 80/20 internet connection, so you aren't the only one with issues (and I originally thought that is was my crappy internet connectivity hardware that goes between the computers and the fibre modem).
