So recently I've have a little bit of a problem typing very quickly.
Instead of using all my fingers I use less than half. I'm a little embarrassed. A week ago I started to type like this again instead of with all fingers.
This is only on laptop keyboards or small keyboards. I'm now as of this post doing 44 words per minute. Even though I used to do 80 words per minute previously.
How do I go back to "normal" typing?
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/538408-typing-issue/
use one of the many free typing classes online
  • Intel Core i7-5820K 3.3GHz 6-Core | GIGABYTE GA-X99-UD3P | Crucial 16GB (2 x 8GB) DDR4-2133 | EVGA GeForce GTX 770 2GB Superclocked ACX | Corsair Carbide Series 200R -- WD Caviar Blue 1TB, Sandisk SSD 128GB | Corsair CX 750W | AOC e2250Swdn Black 22" | Microsoft Windows 7 Home Premium (64-bit) |
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136297
Normal as in all fingers? I'd just use a web service to work on your typing skills. Keybr.com is my go-to
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136304
Just keep doing typing tests, I was at around 65wpm when I was 11 or so, then over the years I went up to ~120wpm. I honestly only use about 3 fingers per hand for typing.
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136311
Instead of using all my fingers to type I have a tendency now to use just two or three (I have quite large hands).
Well currently i'm using 1 or 2 per hand since this problem started.
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136326
Which fingers? On my left hand I use my 4th, 3rd, and 1st finger (everything but thumb and pinky) and my right hand I use thumb and first and third fingers but sometimes use fourth.
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136337
For me it's mainly my index fingers. and thumbs (just for hitting space though)
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136343
4 minutes ago, Agent181 said:
um thats not bad I can do 30wpm on one hand while texting so your fine but I really only use 4 fingers on each hand
Trust me it's quite awful.
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136374
Not sure what to tell you, I cant use my "pinkie" fingers to type with (its a physical thing I cant change). Just do what you did when you first learned to type, be conscious of your positioning.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136385
but how do I get better and use more fingers when I type?
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136597
Well at the risk of sounding obnoxious- practice.
You could try using typing software, it does help.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/538408-typing-issue/#findComment-7136693
