24 minutes ago, Lonewolf7381 said:
So I have a moto x 2nd gen and the port is extremely loose, it's so loose just a couple wrong moves and it falls out. I've tried cleaning it and I tried multiple micro USB cable but nothing seems to work. Anyone else having our had this issue?
As said it sounds like the port itself is damaged so the only way to replace it is to solder on a new port or replace the board that the port is on.
https://linustechtips.com/topic/538325-charging-port-help/#findComment-7135740
