JavaScript is NOT going away
Solved by minibois,
Yeah well..
Javascript != Java. These are two very different languages and no offense but IMO: if you dont know the difference between the two your opinion on Java going away or not is not relevant. If you don't know the difference between the two, you probably dont know the advantages and disadvantages of both.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
