I just got me a AX1200i, but I soon found out that the two 8-pin EPS cables were to short to reach the top of the mohterboard routed behind the mb tray. As I really wanted to get things going, I decided to make cable extensions. I had all the stuff laying around, except the female connectors, so I had to find a different way to isolate all the terminals from each other...
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/53757-ghetto-cable-extension/
LOL? No insulation tape?
I only had this Sellotape, I guess its called in English...
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721642
We call it scotch tape over in the West. But it looks good for what it is :) You gotta do what you gotta do to get things to work.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721645
i like your style bro
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721650
I am the king of cable extensions. You should see some of the cables we use in my band for monitors and that :P
AMD 8350 // 8 GB Corsair Ram // PNY 780 Ti // Asus 1080p Monitor // Antec 120mm AIO // CM Quickfire TK w/ Custom Caps  // RAT 5 mouse // Audio Technica m50x // Behringer 4-line + Line6 8-line Audio Interfaces
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721652
why would you need insulation tape? just don't touch it! and's its only 12, 5 or 3.3 volts, but a deadly amperage.
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721654
The pins could short each other, causing some big problems.
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721659
I already ordered some terminals... I just really wanted to use my new PSU and CPU (4930k) :P
https://linustechtips.com/topic/53757-ghetto-cable-extension/#findComment-721681
