So after plugging my UPS in the wall for the first time, everything looks to work fine - however at about 10 minutes into charging, it started showing a flashing orange LED next to one of the symbols.
So what i'd like help with is: What do the different symbols mean and what does the flashing orange LED stand for?
https://linustechtips.com/topic/537299-ups/
What, did you throw out the manual already?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/537299-ups/#findComment-7125747
Manual is in the workshop - will only be back there on monday
What UPS is it?
https://linustechtips.com/topic/537299-ups/#findComment-7125754
The one with the red circle around it looks like a momentary power surge/voltage rising above safe thresholds.
Above that is the light that comes on when the mains power dies and it switches to battery.
The battery with the cross through it means replace battery.
 Almost as cool as my temps
https://linustechtips.com/topic/537299-ups/#findComment-7125765
-PIC-
That should be Bypass mode where the UPS's battery backup is not going to be used and only acts as a surge protector. It usually trips if the UPS has failed, or if there is very high inrush current from devices starting up.
https://linustechtips.com/topic/537299-ups/#findComment-7126562
Is it anything to worry about?
https://linustechtips.com/topic/537299-ups/#findComment-7130074
