So I've built my PC, and it looks all ready. I've plugged in all the wires I think I've needed. It looked all ready to go, but nothing happened. Obviously I've missed something. After a while of tinkering, I honestly have no clue what I did wrong. I'm sure it's something super obvious, but I still need some help finding what to do to complete my PC.
My PC:
AMD FX 6300K
Stock Cooler
ASRock 980DE3/U3S3
EVGA GeForce GTX 750Ti
EVGA SuperNOVA GS 550W
(That's all I think is important for my problem, if you need any more specs feel free to let me know)
post-253522-0-37996400-1454097902_thumb.
post-253522-0-65433500-1454098014_thumb.
post-253522-0-96293300-1454098022_thumb.
post-253522-0-86500800-1454098030_thumb.
post-253522-0-49062500-1454098045_thumb.
post-253522-0-48073400-1454098055_thumb.
post-253522-0-89996800-1454098064_thumb.
https://linustechtips.com/topic/537265-new-pc-build-need-help/
Is the PSU switched on?
Is the big ass motherboard power cable plugged in tight? The fans should spin a little at least if it's getting power.
VERY CAREFULLY reinstall the headers for the front panel IO, this includes the power button. The power button won't work if these aren't hooked up correctly.
Also, try the RAM sticks in slots 1 and 3, rather than 2 and 4.
 Almost as cool as my temps
https://linustechtips.com/topic/537265-new-pc-build-need-help/#findComment-7125493
