Hi everyone, I was wondering if someone knew how to make a custom window or more importantly a custom cut in a side panel. I would like to cut a design into the side panel of the case so that the window looks like a lightning (i plan to have a frosted window with yellow lights). I have never modded a case before so I was wondering what would be the best way to do this.
Another idea I had for another computer was to cut a lion or other semi-intricate design and was wondering if this is even possible at home or would it need to be sent to a shop or laser cut?
https://linustechtips.com/topic/53713-custom-window-mod-help/
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-720901
Well the basic idea was to cut the metal so there would be a hole (to see the insides and as a design), and attach a window panel behind the metal.
So you want to make a window that looks like a lightning bolt?
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-720924
that's what I'm thinking he's thinking
Well that won't be the easiest. I would still recommend etching here is a nice little guide http://www.tweaktown.com/guides/5391/case-smithing-personalized-acrylic-etching-and-engraving/index.html
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-720936
Thats a great guide and it gave a me a few new ideas, but I wasn't trying to etch the acrylic. I was trying to cut the metal side panels and just have acrylic behind it.
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-720957
I understand what your trying to do now, but it would be tricky to do. I'm no modder, so I will let other people on the forum take over now on helping you. ;)
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-720969
use acrylic for the panel itself, screws for holding it in place, and a dremmel to make a cut in the side panel
I was thinking marine adhesive, such as this: http://www.amazon.com/3M-Marine-Adhesive-Sealant-White/dp/B0065HGC5O/ref=sr_1_1?ie=UTF8&qid=1378443298&sr=8-1&keywords=marine+sealant, but how would screws work?
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-721031
correct me if I'm wrong, but Singularity shows here
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-721048
Ok thank you for the video, thats exactly what I was looking for. Does anyone know how I would go about cutting an intricate design like the lion?
And just so I don't have to open another thread, does anyone know how to get a matte or soft-touch like finish on a computer case?
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-721063
Dremel, Scotch 4010 double sided tape, file.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-721122
Simplest way - Cut the hole you want, use u-channel to clean up the cut, then attach the acrylic from the other side with 3m ultra double sided tape. You can get the acrylic and double sided tape from a hardware store like home depot. Looks fantastic and is cheap.
Here's how mine turned out...
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/53713-custom-window-mod-help/#findComment-721132
