Am I missing something here? I just installed folding @ home and I see that I'm getting very low ppd (relative to what I've seen online). What gives?
my specs are as follows:
i5 4460
h97 mobo
gtx 960 strix
I apologize in advance for my possible unfathomable ignorance.
~ Luc Luc
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/
CPU folding doesn't give much PPD as GPU folding
Also wait a few hours before seeing PPD, it takes a few hours to see PPD.
Although the display is kinda pointless for me and i just check logs instead.
I assumed gpu folding was being used considering it listed my gm206 960. Please correct me if I'm wrong.
~ Luc Luc
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7121750
Well if you have a GPU slot used then GPU folding is in use.
Although PPD is pointless from the program there IMO, you can find the PPD yourself from logs.
Just calculate the time per percent done in the logs and use the calculator here
Like use the time difference between 0 percent and 1 percent, etc.
http://www.linuxforge.net/bonuscalc2.php
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7121758
Thank you for your insight :)
~ Luc Luc
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7121760
Just to clarify, your estimates are out of whack because you have done less than 1% of the wu.
The client doesn't have anything to work with yet, let it do a few percent and see what happens.
Also, remember that you need to use a passkey that meets the requirements to receive QRB
which makes up a big portion of the overall ppd, especially on gpus.
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7121810
Mmm I find the client a little off.  It can be close but sometimes a little RNG, especially at the commencement of a new WU and just as it's finishing one so if you look at those moments and base any calcs on that, you're not likely to be in the ballpark.
I find the best place to obtain a true average is to look yourself up on the Extreme Overclockers Database. This gives a daily point count, a moving 24hr average (nothing is more accurate than this) and can be broken down into hours, weeks, etc.
This information is updated every 3hrs.
Here's the link to our team's overview
http://folding.extremeoverclocking.com/team_summary.php?s=&t=223518
CPU: i7-5960X @ 4.5Ghz MB: Rampage V Extreme GPU: Titan X (self OC) Mem: 32GB Corsair Dominator Platinum DDR4 @ 3000 PSU: Corsair AX1200i With Green/Black Sleeved Cablemod Cables, Case: Corsair 900D KB: Corsair K95 RGB Cherry Red, Mouse: Logitech G502 + Destructor 2 Mat, Sound: Logitech Z623 Speakers, Display: 2x Samsung BX2440's, Cooling: Corsair H100i on CPU. 5x 140mm Intake fans + 1x 140mm Exhaust.
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7121905
You have to fold for a little while to get a proper estimate, the number isn't known immediately.
I let it run for a while. Now the ppd is much higher :D. Even on the medium setting.
Thank you for your people for help!
~ Luc Luc
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7124200
I was about to mention the seemingly low ppd for a 980, just now seeing you have a 960,
guess i solved the riddle.
Nice that it's working, as someone has already mentioned you can look up stats and
such over at extremeoverclocking: http://folding.extremeoverclocking.com/
It isn't a very good indicator to see whether something is acting up or not though, i
would just use the local client for that. Gpu-z, cpu-z and so forth.
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7125083
i5 4460
h97 mobo
gtx 960 strix
Give it time. The GPU probably isnt doing much right now, but as soon as it does you will get many PPD (60,000+)
Breaking things 1 day at a time
https://linustechtips.com/topic/536944-exceptionaly-low-ppd/#findComment-7125358
