  • i7 3770k @ 4.2ghz
  • Asrock extreme 6
  • sli gtx 680 4gb
  • 850w psu
  • 16gb of ripjaws 1866 ram 9 10 9 28
The problem I am having is with most games , and i feel with this setup i shouldn't have any frame issue on most any game. I have tried everything that i know to do like test both GPUs on their own, and update drivers.
I play all my games at 1920 x 1080 on max settings or really close.
  • Borderlands 2 will drop below 50 fps on single player
  • BF3 will drop under 40 fps on some maps like B2K and AK map packs
3DMark 11 scores:
3DMark Score P15837 Graphics Score 21669 Physics Score 9217 Combined Score 8159
3DMark Score
15837.0
Graphics Score
21669.0
Physics Score
9217.0
Combined Score
8159.0
Graphics Test 1
102.8
Graphics Test 2
100.3
Graphics Test 3
132.8
Graphics Test 4
65.6
Physics Test
29.3
Combined Test
38.0
https://linustechtips.com/topic/53582-frame-rate-issue/
Default settings used
Yes
Screen width
1280
Screen height
720
MSAA sample count
1
Texture filtering mode
Trilinear
Max anisotropy
1
Tessellation Detail
5
Max Tessellation Factor
10
Shadow Map Size
5
Shadow Cascade Count
4
Surface Shadow Sample Count
16
Volumetric Illumination Quality
5
Ambient Occlusion Quality
5
Depth Of Field Quality
5
Windowed mode
Off
Vertical sync
Off
Triple buffering
Off
Wireframe
Off
Color saturation
100%
https://linustechtips.com/topic/53582-frame-rate-issue/#findComment-719122
At what point does Borderlands 2 drop in FPS?
https://linustechtips.com/topic/53582-frame-rate-issue/#findComment-719186
http://www.3dmark.com/3dm11/5653119
That's mine so your getting a score that you should be.
BF3 shouldn't be dropping below 60fps at any point and neither should BL2.
I don't know how the scoring works for 3dmark11 but your physics score isn't much higher than mine. Is that a proper score for a 3770k?
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/53582-frame-rate-issue/#findComment-719214
after you have killed everything and you look at all the things they drop and the bodies and also during the battle
its close maybe 9 - 12000
https://linustechtips.com/topic/53582-frame-rate-issue/#findComment-719236
It may be a driver problem. Have you updated your drivers recently? If not, try updating them. If you have, try reverting back.
https://linustechtips.com/topic/53582-frame-rate-issue/#findComment-719273
Try disabling SLI and then playing one or both of the games.
https://linustechtips.com/topic/53582-frame-rate-issue/#findComment-719330
