Primary monitor rez problem
JoySkeet
Hello , my primary monitor won't work in high resolution (1920x1080), it makes the image VERY VERY blurry and half my screen goes to the second monitor
If i keep it on native it works perfectly , how do i make it work in higher res?
http://i.imgur.com/yWZN6uu.jpg
Are you sure it even supports higher res than the native shows?
It's not a monitor , it's a TV haha :D shouldnt it support more?
TV's also have different resolutions. Try messing with settings with TV menu itself.
I have to set my TV to 'Dot by Dot' from 'Full' when I connect laptop, then it plays HD else it's just not right.
