Does anyone know of a chassis mountable IEC cable? I know that there are ones that you can attach to a cable yourself, but I'm looking for ones that are put on beforehand.
Like this it has a mountable socket on one end and a plug on the other:
http://www.alibaba.com/product-detail/Computer-Power-Extension-Cable-Male-to_293497126.html
https://linustechtips.com/topic/535253-mountable-iec-cable/#findComment-7100847
iec 13 or 14
https://linustechtips.com/topic/535253-mountable-iec-cable/#findComment-7100866
Was gonna buy this but realized that it is for businesses and is meant to be ordered in the thousands...
Anything exactly like this but on another site? The right angle other side is pretty much a necessity.
https://linustechtips.com/topic/535253-mountable-iec-cable/#findComment-7110094
Found one place that has it, and at different cable angles:
https://www.ncases.com/product/M1%20Accessories
M1-power-cable-right-angle-380mm-600x450
https://linustechtips.com/topic/535253-mountable-iec-cable/#findComment-7110543
One more thing... That would work but it would be easier if it was one in which the right angle bent forward instead of left or right.
I'm not sure if you will be able to find something like that, it probably exists but not very commonly though, if you see SFF cases with power extensions like that they may have a parts option to buy it from.
https://linustechtips.com/topic/535253-mountable-iec-cable/#findComment-7110962
