Depends on your cooling and you can also isolation to the case.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091532
Fractal Define R5 is a pretty good sound dampening case.
Like mentioned above though, you'll need to get silent fans and such.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091548
Silent Base 600/800
I think. Also, you can have an extremely soundproofed case and still hear noise, you need silent components like Noctua/be quiet! fans, fanless (mode) PSUs, graphics cards with fan stop modes and a large heatsink (with or without quiet fans :P)
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091555
I will not be able to isolate the case, it has to sit on my desk.
Also, I'll either be going with a H110i GTX or a Phanteks PH-TC14PE
why can't you isolate when it's on the desk?
But this inside:
http://www.akasa.com.tw/update.php?tpl=product/product.detail.tpl&no=181&type=Accessories&type_sub=Acoustic%20Silence%20Kits&model=AK-PAX-2
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091564
Silent Base 600/800
Well all this information is a given, I only need the information bit on the part of, which case is best at damping sound. I guess.
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091565
You mean insulate? Or something of those terms?
Isolate means to locate it somewhere else away from me.
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091574
get noctua fans with low noise adapters one of corsair quite series cases and buy a bunch of sound dampening foam
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091812
oh and make sure to put some sound dampening foam on your hard drive (or use an ssd) because with noctua and low noise adapters thats most likely what your going to hear
https://linustechtips.com/topic/534474-best-silent-case/#findComment-7091833
