Light Gaming/Rendering Build
1. Get at least a 1 tb hdd since it only costs a little more for double the storage.
2. Get the newer 850 evo for you ssd instead of the older one. However, if you don't need 500 gb the 250 gb version costs about half.
3. As others have said get at least an i5 4460. If you can afford it jump at a 4690k or 6600k.
4. 16 gb ram since you will be rendering.
5. If you are doing VR gtx 970 is bare minimum, so you should try to get something better. Also, if you can wait until the summer AMD and Nvidia are releasing new GPUs that will be a huge improvement, so you might want to wait for that, especially since VR won't be hitting the market until after those hit the shelves.
6. If you can't afford anything more than a gtx 970 the amd r9 390 is a better performer at the same price.
