My Operating System is F*** Up
After trying to install a lot of different versions of windows in my 2 HDD along with Easy BDC and PaePatch i aam in a state where everything is a complete mess. In this point i cant install an operating system in any of my drivers since everytime i use a USB or a DVD to a clean HDD it shows me up the Windows icon for windows 10 or is says Starting soon and for windows 7 for a while and then the pc restarts or just stay like this.Nothig happens at all. Even if i try to install windows 10. What should i do?
https://linustechtips.com/topic/532992-my-operating-system-is-f-up/
Im not familiar with Easy BDC or PaePatch. Boot in to your BIOS/UEFI and check your settings. Also make sure your drives show up their. Make sure your boot priorities show that you want USB/DVD drive booting up first. Then as long as you dont have important data on the drives you might want to Wipe them.
Are you trying to dual boot (multiple OS on one machine)?
